Use this procedure to clear the Neighbor Discovery inspection statistics.
The following table defines parameters for the clear ipv6 fhs statistics nd-inspection command.
| Variable | Value |
| {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} | Identifies the
                                    slot and port in one of the following formats:
